So im looking to get some drive shafts made to complete my conversion but have come up against a problem:
When contacting Rob at allspeed he says the teeth for the CG13 shafts are 22t at the micra end of the Drive shaft ( and obviously 19 at the mini end). Now i can only count the splines in the Gbox and there are 23/24 depending on how you count it. I dont have an actual drive shaft to count the teeth on - only the inner CV / G/box hole if you follow? Im assuming there ARE 22t on the end of the 1.3 driveshaft but then the inner CV it is connected to has more teeth?
Has anyone done this conversion to confirm?
Thank you!
