Removing Rebound Rubbers
7 replies to this topic
#1 blackjack1986
blackjack1986
  • 107 posts
Posted 24 January 2015 - 10:54 PM
Tried removing rebound rubbers this evening and the fixing screws are not moving at all! Don't want to force them and strip the screws. Any ideas how to remove them?
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 January 2015 - 11:03 PM
Do you mean the bumpstops?
#3 blackjack1986
blackjack1986
  • 107 posts
Posted 24 January 2015 - 11:04 PM
http://www.minispare...76.aspx|Back to
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 January 2015 - 11:06 PM
You could try plusgas but obviously it will burn the rubber so be prepared for that
#5 FlyingScot
FlyingScot
  • 2,664 posts
Use an impact driver, or cut a slot across the head with a junior hacksaw and use a big plain screwdriver.
FS
#6 nicklouse
  • 18,696 posts
Posted 24 January 2015 - 11:35 PM
Plus gas them overnight or two.
Not much of an issue if you mash the head. Just drill out and replace.
#7 Stu1961
Stu1961
  • 636 posts
  • Local Club: Still Looking
Posted 25 January 2015 - 01:25 AM
I used a pair of mole grips to get mine out just do them up real tight on the head, if the screw breaks off just drill it out and run a tap through the captive/welded on nut I think it's 3/16"UNF. If that doesn't work drill the nut out to give a small amount of clearance then put a slightly longer screw in then fit another nut on top of the existing one, a bit fiddly but should work.
#8 blackjack1986
blackjack1986
  • 107 posts
Posted 25 January 2015 - 06:27 PM
Thanks everyone I'll give this a go next weekend.
