I have brought 5 litres of cellulose flame red for my car and 2 litres of jet black for the roof and arches, my question is should I sand down to bare metal as the currant paint is of very bad quality, and also when painting onto bare metal what paint do I need? I have some high build grey primer, which I presume has to be mixed with thinners like the paint? and does anything have to go before the primer?
Cellulose Painting
Posted 27 January 2015 - 06:36 PM
Posted 27 January 2015 - 06:49 PM
Posted 27 January 2015 - 06:56 PM
what is epoxy? will the metal just rust without it?
Posted 27 January 2015 - 07:10 PM
Posted 27 January 2015 - 07:16 PM
High build primer needs a key to adhere to and either etch primer or epoxy primer bonds to the steel and gives a key for other coats to adhere to. Epoxy is also resistant to water so for working at home when everything isn't done in a controlled booth and may have longer time between coats can be better than etch but is a little more expensive.
do you know where I can get this?
Posted 27 January 2015 - 07:56 PM
http://refinishsyste...poxy-primer-kit
I think jawel do an epoxy primer as well, just I have used this exact one and found it good
Posted 27 January 2015 - 08:02 PM
I bought this one, went on very well and had a good build so on my bonnet and doors I just flatted it with a guide coat and put the colour straight on
cheers for the help with that:), how much would the car take?
Posted 27 January 2015 - 08:07 PM
Posted 27 January 2015 - 08:08 PM
I will get some then, then should be ready for paint when weather warms up a bit!
Posted 27 January 2015 - 10:01 PM
This is a 2 pack product and you will need to use the appropriate breathing apparatus, just be careful.
Posted 05 February 2015 - 04:35 PM
2 PACK , EPOXY PAINT IS VERY DANGEROUSE !!!!! ,As Above be very careful do not use it in enclosed spaces , do not breath in the fumes if you do before you know it you will be gasping for breath and could be fatal , if there is anyone with more experience with this paint please give this lad more details !!!! , Shawbags.
Edited by Shawbags, 05 February 2015 - 04:41 PM.
Posted 05 February 2015 - 04:51 PM
yes mate thanks for the info, I will get relevant breathing apparatus when I come to paint, I understand the dangers of 2 pack paint and will get full safety equipment
Posted 05 February 2015 - 04:58 PM
YOU CAN HIRE THE BREATHING GEAR BUT MAKE SURE THE FILTERS ARE FOR THE PAINT YOU ARE USING , A BLOKE KILLED HIM SELF A FEW YEARS AGO IN MY AREA HE PAINTED A WING ON HIS CAR IN THE GARAGE WITH THE DOOR SHUT , IT TOOK ABOUT 5 MINUTE HE WAS DEAD , THE PAINT HARDENS IN YOUR LONGS , NASTY STUFF , CHEERS AND TAKE CARE .
Posted 05 February 2015 - 05:07 PM
Please can you type in lower case shawbags.
Posted 05 February 2015 - 06:00 PM
http://www.rust.co.u...-primer/c32736/
