Front Subframe Rear Mount Guide
8 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 31 January 2015 - 10:43 AM
Hi does anyone have a guide or tips on swappin the front subframe rear mounts on my mini please ( http://www.minisport...nting-each.html I bought the ones) im wantong to do them before show season so any help will do :)
#2 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 31 January 2015 - 11:50 AM
Not as tricky as you might think. The bolt heads for these are located under the footwell carpet. I jacked the car up one side at a time to do them using a second one to support the subframe from sliding backwards and closing the gap.
#3 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 31 January 2015 - 12:06 PM
How often do the bolts snap if they have been in for a long time?
#4 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 31 January 2015 - 12:10 PM
Wire brush the threads as best you can then douse them with WD40 the night before :)
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 31 January 2015 - 01:07 PM
the bolts for these are ussually pretty easy to get out as they get covered in oil.
#6 Cerberus
Cerberus
  • 989 posts
Posted 31 January 2015 - 02:11 PM
+1 on this.
Mine were very oily and came out easily.
Even if they do snap, you'd just push them out, they're not captivated or anything (atleast mine weren't).
#7 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 31 January 2015 - 02:17 PM
Has anyone got a picture of what to undo and where?
#8 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 31 January 2015 - 02:44 PM
Get under the car, its pretty self explanatory.
#9 Ado1379
Ado1379
  • 588 posts
Posted 31 January 2015 - 02:50 PM
its fairly simple mate...
if the bolts have snapped, peel back the carpet in the relative footwell, and you will see the bracket with the 2 bolts in it. it just pushes out when your mounts are off. undo the 4 nuts on the mount itself and pop the bracket holding the screws in (should just pull out from inside the car in the footwell).
there are a few ways of support the frame so the gap doesnt close too much:
1. what Steve said above, use another one (or something similar to prop the gap open)
2. rest a jack on the front of the subframe (just rest it on the subframe, dont put to much pressure on it)
i used the second option last time i did this, because you can usually lower/heighten the jack 'SLIGHTLY' to adjust the gap diameter.
Edited by Ado1379, 31 January 2015 - 02:50 PM.
