Fitting An Exhaust?
6 replies to this topic
#1 TSK95
TSK95
  • 17 posts
Posted 31 January 2015 - 07:38 PM
Hey guys,
Ive got a '77 mini 1000 with what I think has an 850 in it (I bought a proper botched one I think) And drums all round.
Its got a standard manifold with an su carb, but I want to stick a Fletcher 3 inch on it, I know I need an LCB manifold and a new inlet, but from what I see all the inlets seem like they are for hif carbs? And they all seem Water heated and my current inlet/Exhaust isn't.
What do I need to do in order to fit the exhaust? Can I use a water inlet? Im so confused right now someone help!
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 31 January 2015 - 07:51 PM
a magic pipe would do the job , this fits from the existing manifold and joins on to you very oversized exhaust
#3 Tupers
Tupers
  • 4,173 posts
Posted 31 January 2015 - 07:58 PM
There's not much point going to the expense of fitting a separate exhause and inlet manifolds if you're set in have a 3" exhaust. It'll make a lot of noise but will loose power so just go with a magic pipe on the standard down pipe.
#4 TSK95
TSK95
  • 17 posts
Posted 31 January 2015 - 08:00 PM
Ah I see, thanks for that! But just out of curiosity If I was to fit an LCB would I have to change carbs? and find a way to allow water through the new inlet?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 January 2015 - 08:15 PM
Your current inlet is heated by the exhaust. If you swap to an alloy inlet then yes ideally for a road car it will be heated but many people don't bother hooking it up. It's easy enough to do though. You don't want an LCB for a small bore engine though, you should fit a Cooper Freeflow instead. You won't need to change carb, there are inlets for all carbs. An 850 with a 3" exhaust will give a horrible driving experience incidentally but it's your car.
#6 Cooperman
  • 23,513 posts
Posted 31 January 2015 - 08:29 PM
The best size exhaust for an 850 is a 1.625" internal diameter with a 3-into-1 tubular manifold.
With the power loss a 3" exhaust would give on an already less-than-powerful 850 the performance would be ghastly (think Citroen 2CV :D ).
But, as said, it's your car, as Dan so rightly says.
Edited by Cooperman, 31 January 2015 - 08:30 PM.
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 31 January 2015 - 08:32 PM
A 3" Exhaust once fitted I'd put money on your next post being my car doesn't pull like it used to and there is a flat spot at ????rpm.
