Crvtec Mini
9 replies to this topic
#1 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 31 January 2015 - 11:55 PM
Been lurking around the forums for about a year while I have been collecting parts for my conversion. I bought my car as an unfinished project that came with a Kawasaki zx9r engine in it. After getting it driving with the FNR differential box in it, it be aparent that it was geared way to low, later found out that the gear box had a 12:1 reduction in it. I could only go 30 mph in 6th gear at 10,000 rpm so I took out the gear box that came with it and started exploring my options for a chain drive differential and after seeing the costs of the differentials I decided I would just replace the differential with a solid axle temporarily to make sure I could get the gearing right. We got that driving after some trial and error and the car was scary fast but was lacking a differential as well as reverse. At this point I decided I wanted to go with a vtec conversion. I began ordering parts from minitec and about a month ago I had enough parts to get started.
The first series of pictures are from when the previous owner had the car
340514_191613307574151_532209461_o_zpsce
336998_191613714240777_918363143_o_zps1f
334414_191613177574164_926476358_o_zps51
312951_191611667574315_1433385270_n_zps1
309598_191611620907653_223344266_n_zpse5
This was from the first day I had my mini
Its temporary home I was building for other purposes, I later added on to the shed
10252011_10203149925645745_5181522854253
We had to add a fuel cell, since the car didnt come with the orinal tank, my fabricator made a quick cage to hold the fuel cell
1157540_10202894278294721_243508047_n.jp
This was the gear box that came with the car, had a 12:1 reduction in forward and a 14:1 reduction in reverse, it was kind of fun being able to drive in reverse and go through all 6 speeds but it was to slow 1452020_10202894279214744_396421412_n.jp
So I took it out and put a bar in it place
1538799_10203149736761023_83168457054256
Cut the ends of the axles off and welded them to a 1-1/8" solid bar
10176111_10203149735560993_1881341203841
1656195_10203149734760973_56477879784985
10170778_10203149734400964_8511135283232
1491733_10203149733960953_56793654085929
My Extra super duper limited slip diffential set up
10151795_10203149299430090_3442983711521
10168183_10203149327470791_2643155690450
10173526_10203149841163633_1052660466453
After months of looking for an engine My friend told me about his B20 block with a b18gsr head on it, and long story short I bought it, and we rebuilt it adding arp rod and head bolts.
A sign of possible things to come
At this point we were ready to start
The first day of tear down for the Vtec build
Bought a new welder for my project
Decided I didnt want to cut the intake manifold as suguested by minitec, so we boxed in a bulkhead, we had to bend the bracket that came in the kit supplied by minitec for the brake and clutch pedals, then we cut and angled the crosmember to match the predal bracket so we would have clearance for the intake manifold. At this time the buts were welded in place to aid in intsallation of the pedals.
We still have to add drain hoses so no water is collected
This is where we left off after two weekends and since We couldnt work on it this weekend I would take the time to share my project.
#2 cal844
cal844
  • 9,643 posts
  • Local Club: TFMOC
Posted 01 February 2015 - 09:30 AM
Wow this will be quick!
#3 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 02 February 2015 - 01:14 AM
I bought the wiring harness supplied by minitec and before all my lights were covered by the Ninja wiring so i bought a watertight fuse and relay box, wiring, sleeving, heat shrink, and a soldering iron and started making my own.
The dash pod I got from minitec, not quite sure how i am going to use it now that I cut the bulkhead
#4 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 10 February 2015 - 04:53 AM
I placed an order tonight for my fuel line, fuel pressure regulator, and fuel rail which should be everything I need to start my mini this weekend
#5 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 17 February 2015 - 01:56 PM
ScreenShot2015-02-17at54944AM_zpsc5730d9
Put the engine in for the last time this weekend
ScreenShot2015-02-17at55026AM_zps408c56c
craig built me shift linkage, only took two tries to get all gears
ScreenShot2015-02-17at54915AM_zps3fe30fe
He also built me my exhaust
ScreenShot2015-02-17at54903AM_zpseaf7e76
Then I parked on top of a subaru
ScreenShot2015-02-17at54925AM_zpsc0a4bfa
Edited by jsm, 17 February 2015 - 02:02 PM.
#6 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 17 February 2015 - 01:59 PM
That's all I got for the weekend, its hard to remember to take photos while im going
Edited by jsm, 17 February 2015 - 02:12 PM.
#7 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 25 February 2015 - 02:42 AM
Aluminum bracket for master cylinder reservoir
Brake and Clutch lines
Pedal Box
Also got my new studs in the rear and 1 inch spacers so I can install my rear wheels now
#8 jsm
jsm
    Just On Tickover
  • 9 posts
Craig welding the T3 flange on
Decided that when I install the roll cage the back seat wasnt going to be very usable anyways
Pipe welded in to couple the charge pipe that will run inside the car to the pipe in the engine bay
#9 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 25 February 2015 - 02:43 AM
I started my mini for the first time yesterday, hopefully will finish the charge piping this following week so I can take it for a test drive
10985932_10205463590965932_8909002387692
10991290_10205463591325941_2383892751082
10994458_10205463592485970_1906794880722
10995804_10205479478843119_4972044832153
#10 jsm
jsm
    Just On Tickover
  • 9 posts
Posted 04 March 2015 - 05:58 AM
https://instagram.com/p/zydbRnTLhz/
