Hey all,
I had the tank out not so long ago to get access to the top shock nut and when putting it all back it occurred to me that the seam of the petrol tank sits in direct contact with the boot floor, and when wrestling around with it, it scratches away at it.
Should there be a rubber strip on the seam? If not a standard fitment, has anyone tried using rubber strip on this to protect the floor and if so, any suggestions as to what is good for this purpose? I was thinking about a piece of the seam strip that goes onto the doorstep / sill seam, but not sure if that would be too thick and maybe upset the alignment of the tank neck with the hole.
Craig
