Turn Indicator Switch
4 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 05 February 2015 - 09:55 PM
I am trying to determine if my 1974 Mini 1000 turn indicator switch is faulty.  I presume that the switch in a Mk III car is intended to operate the high beams, and the car has no floor mounted dip switch.  The switch lever has a spring-loaded high beam flash position (rearward), but it does not have a detent for selection of low beam/high beam.  The part number on the switch is 119 SA.  Is this the correct part number for a Mk III?  Is the switch faulty?
Attached File  Optimized-DSCN6202.JPG   82.17K   1 downloads
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 05 February 2015 - 10:17 PM
I would say the plastic overthrow ramp has broken inside the switch between dip and selecting main beam, there is usually a positive selection to ensure the actual contacts remain tight, without the contacts will burn and melt the switch assembly.
#3 newenglandmini
newenglandmini
  • 646 posts
Posted 05 February 2015 - 11:21 PM
Cheers again mate!  I'll order a new one.
I found this wee bit near the switch when I removed it.  Do you reckon it's the bit you mentioned?
Attached File  Optimized-DSCN6218.JPG   21.13K   5 downloads
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 February 2015 - 04:02 PM
Looks like it
#5 newenglandmini
newenglandmini
  • 646 posts
Posted 09 February 2015 - 10:26 PM
Thanks Dave.  I've added a new switch to my list of parts to ordered.
