I am about to start doing some research into this, but the knowledge here is quite good so thought I would ask here first.
I have three problems with the Focus at the moment, and would like to get them all sorted fairly soon as planning on driving to France or Austria for skiing in a couple of weeks.
Problem 1 - The speedo - it randomly just cuts out. The needle drops to zero, even though there is no change in speed, and the odometer stops increasing (which isn't that surprising given the needle is reading 0). Sometimes, the display will display dashes and all the numbers disappear. It normally last for a few seconds, and then jumps back again. Today it lasted for a few minutes. A few times I have found dropping to 4th and then going back to 5th has bought it back, or it may just be coincidental timing, but that trick hasn't worked the last couple of times. I'm thinking loose connection at the gearbox end.
Problem 2 - Engine cuts out - a few times the battery light has come on, quickly followed by oil light and then the engine management light (at which point the engine has cut out). It has always started again straight away. When the garage changed the timing belt, they told me that the auxiliary belt tensioner wasn't tightening the belt enough. I thought they were trying it on for a bit of extra cash so said I can do it myself. Is it likely to be this? I've had a look and at idle, all the pulleys still seem to be turning fine. I have not had a problem starting the car at all, the temperature gauge doesn't go above half way and I can't think of any other symptoms. This has only happened since I had the timing belt done a short while back - the car runs fine and I don't believe the timing to be out or anything like that.
Problem 3 - scraping sound - whenever the steering wheel is turned even a little bit to the right, there sounds like a scraping sound or something coming from the nearside front wheel area. I was thinking it might be a bearing, but thought that would make it all the time and that it's probably more likely steering related.
Any help on any on of these would be much appreciated, and I am now off to scour the Ford forums for any useful info.
