Lucas 'sport' Dlb105
6 replies to this topic
#1 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 07 February 2015 - 05:36 PM
After our 998 mini getting a clutch kit last year, it was sluggish and felt like it was running lean(juddering and missing under load)
We'd changed carb, dizzy and tried 3 coils(all 12v, with ballast resistor bypass)
Bought a new AAU needle and changed the coil for the one we fitted along with electronic ignition(65D dizzy) four years ago... Problem solved
Anyway, my question is: has the DLB 105 COIL issues been resolved yet??(coil was bought in september last year)
#2 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
Posted 07 February 2015 - 05:53 PM
DLB105 won't work with the 65d dizzy, you have to run one compatible with the electronic ignition. I can't comment on the quality, we will no longer stock them
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 February 2015 - 07:12 PM
O.E Electronic Ignition 89-on DLB198
This is the standard coil as used on the late Mini with factory electronic ignition. This was a Genuine Rover fitted part on 1275cc. GCL211 is the same equivalent as GCL143 but from Unipart. 1 ohmn
SPI also used the CGL 143 Coil
Lots of posts on the internet where these DLB 105s have failed. or gone pop and blew the end off. I removed mine when I found out the numbers failing in conversation with Minispares, I now have a MSC 105 Sports coil made by Intermotor.
You need either a DLB 198 or GCL 143 to use with your 65D4M distributor
#4 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 07 February 2015 - 09:59 PM
The one fitted was a DLB 105,changed for a GCL143 (which was on the car previously) and its solved the fault(which ive now learnt is the correct one!)
Edited by cal844, 07 February 2015 - 10:00 PM.
#5 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 07 February 2015 - 10:00 PM
Thanks again folks!
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 February 2015 - 08:32 AM
It's lucky the Sportscoil coil failed and made you swap it out really, running the dizzy on a higher impedance coil destroys the module after a while.
#7 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 08 February 2015 - 11:17 AM
We initially thought the modfule had failed Dan, but changed the coil and a couple of plugs :)
