Hi All,
Have just tried fitting my new 7.5" discs (Mini Spares) and am having an issue with them rubbing on the hubs not the friction area but inside the top hat area of the disc, they are ok until you tighten the hub nut any more than finger tight (Will not be able to tighten them to any degree as subframe is out of car).
Hubs have been rebuilt using Timken bearings and as far as I am aware everything else is fitted correctly. 8.4" discs were fine before rebuilding but have since given them to the tat man so I can't see if they fit ok on my hubs now.
Cheers for any help in advance.
Stuart
Will put some pictures on photobucket shortly and post a link.
