Hi all, I need to find out what Minis were fitted with the remote gear change that had the sandwich plate type fixing and not the 4 bolts from underneath. I have a gearbox with number 22G1128 with sandwich plate fixing and want a list of all cars it was fitted to. Any help will be greatly appreciated. Thanks, Marc
What Minis Were Fitted With Sandwich Plate Remotes?
Posted 08 February 2015 - 05:50 PM
Posted 08 February 2015 - 05:57 PM
I always thought that those gearboxes were only on Morris / Austin 1100 / 1300s
Posted 08 February 2015 - 06:12 PM
See I've been told they were fitted to those but I thought they were fitted to Minis as well???
Posted 08 February 2015 - 06:14 PM
As Greenwheels states. This type of gearbox / remote fixing was only fitted to the 1100 / 1300 models, Never to the Mini.
Any found in Minis have been swapped from a 1100 / 1300.
Posted 08 February 2015 - 07:52 PM
It's likely that some made in South Africa and maybe even Italy did, they seemed to do 'off beat' things in an attempt to refine the cars
Posted 08 February 2015 - 07:55 PM
No UK built ones had them as standard.
Posted 08 February 2015 - 07:58 PM
pretty sure the remote for the sandwich type was longer than the normal remote by quite a bit.
Posted 08 February 2015 - 08:10 PM
Posted 08 February 2015 - 08:54 PM
To sum up.
And no Aussie Mini left the factory with them either.
Posted 08 February 2015 - 10:10 PM
read as :
It's likely that some made in South Africa and maybe even Italy did, they seemed to bodge things in an attempt to jam together the cars
Edited by Artful Dodger, 08 February 2015 - 10:10 PM.
Posted 08 February 2015 - 10:14 PM
These remotes will fit in place of the solid Mini remote type, although the rear mount is different, but you can change it to the Mini mounting by drilling/tapping the two holes necessary to carry the Mini remote mounting. If it has been already modified by a previous owner it can give some the impression they were fitted on Mini's as standard
Apparently Authi Mini's used the 1100/1300 remote & sandwich plate it has been reported on the Mk1 forum during a similar discussion.
However knowing some of the other unofficial oddities and mix ups that have since been proved to have left the production lines in the 1960's and 70's, during parts shortages and frequent strikes at suppliers i guess it is entirely possible that some unofficial hybrids crept through to keep the lines running.......
Edited by mab01uk, 08 February 2015 - 10:39 PM.
Posted 08 February 2015 - 11:34 PM
read as :
Bhahaha,,,,, love it,,,, though they weren't the only ones,,,,,,,
