Hi folks,
Whilst replacing my steering rack, I took the opportunity to replace the well squashed rubber subframe tower mounts. I have gone for poly on the bottom, solid metal on the top. When putting it back together, initially I retained the large metal washer under the bolt head. However as I was tightening up it never came to a 'stop' - I have always found in the past that the bolt tightens until it stops, ie the bolt shoulder is hard against the subframe. I looked at the poly mounts and they seemed very squished.
So, I backed the bolts off, removed the washer and did them back up again. This time the bolt tightened down to a stop, the poly bush looked just a bit squashed (I checked and I could not move it so it seems to be 'trapped' OK') and the metal top mount seems secure. I think this is the correct arrangement.
Just wondering if others kept or discarded the washer when fitting solid top mounts? And do you agree with me that the bolts shoulder should bear against the subby (and therefore come to a stop) rather than be tightened to a torque value as a measure of the clamping force on the crossmember / mounts?
Craig
