Engine Fitting And Skinned Knuckle Prevention
10 replies to this topic
#1 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 09 February 2015 - 07:52 PM
Anybody know if it is possible to fit an engine with radiator and hoses attached into a normal fronted mini??
Only to save skinned knuckles trying to fit the lower hose and jubilee clip....
#2 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 09 February 2015 - 08:10 PM
I'm sure I fitted my engine with it fitted.
#3 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 09 February 2015 - 08:13 PM
I have always fitted the bottom hose to the radiator secured the clip and then feed the radiator into position, find it much easier, never tried fitting engine with rad, may be possible but would be a tight fit, found my method easier.
#4 Tupers
Tupers
  • 4,148 posts
Posted 09 February 2015 - 08:21 PM
I always lift engines in and out with the radiator on as I find it quicker. I do use a Sykes Pickavant lifting bracket which helps.
#5 A-Cell
A-Cell
  • 1,610 posts
Posted 09 February 2015 - 08:34 PM
Yep. I always remove and re fit the engine with radiator on.
#6 lsto
lsto
  • 597 posts
Posted 09 February 2015 - 09:01 PM
Mine went in and out complete.
#7 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 09 February 2015 - 09:18 PM
That's bloody brilliant news.......its a goin' in with rad n hoses fitted..
Knuckles saved.....
#8 Spider
  • 14,867 posts
Posted 09 February 2015 - 09:30 PM
Yes, I wouldn't do it any other way!
#9 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 10 February 2015 - 01:48 PM
We fit the engine, then the rad with bottom hose
#10 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 10 February 2015 - 01:56 PM
I've always removed and put engines back in with radiator fitted never had a problem doing it this way
Dan
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 February 2015 - 02:13 PM
I remove the top bracket but very rarely the radiator.
