Drivers Door Dropped
Posted 09 February 2015 - 09:52 PM
Posted 09 February 2015 - 09:53 PM
You need to add a shim under the bottom hinge but be careful not to add too much.
Posted 09 February 2015 - 09:54 PM
You need to add a shim between the door post and the door hinge at the bottom,.
Posted 09 February 2015 - 09:58 PM
Posted 09 February 2015 - 10:01 PM
Thin bit of metal, just depends how much you need to move the door. you can buy them but are very easy to make your self.
Posted 09 February 2015 - 10:02 PM
Posted 09 February 2015 - 10:03 PM
Stainless steel would be ideal. Using washers is not ideal as you really need the whole hinge contact area to to touch the door post.
