Bonnet Jammed
Posted 09 February 2015 - 09:53 PM
Upon fitting my new bonnet I loosely bolted it onto the brackets and pushing it shut.
Now I need to adjust it to sit right but can't get it open.
Any ideas?
It's an external release mk3 van bonnet.
Much ta
Matt
Posted 09 February 2015 - 09:56 PM
is it that the pin is not disengaging? if so give the bonnet a wiggle with the handle pushed over and lift it slightly at the same time.
Posted 09 February 2015 - 10:34 PM
Try wiggling it, whilst applying slight pressure forwards on the badge area. Usuly works when mine gets stuck!
Posted 09 February 2015 - 11:07 PM
Posted 10 February 2015 - 06:02 AM
Much ta.
Posted 10 February 2015 - 07:19 AM
There is a tool for this, standby, I'll find it and post it up
Posted 10 February 2015 - 07:34 AM
If wiggling don't work, then I usally remove the grill and use a screwdriver to push latch.
Posted 10 February 2015 - 07:36 AM
If it has the mini van front panel, which i assume it does, there won't be a grille to remove!
I think as stated it will be pushing the bonnet around and stuff to get it open.
Edited by Yams, 10 February 2015 - 07:37 AM.
Posted 10 February 2015 - 07:53 AM
I have the van grille on it fitted with quick release nobs, ill try taking that off tonight and give that a go!
Posted 10 February 2015 - 08:22 PM
Took the front grille off, then managed to move the pin around to free up.
Ending up having to bend the pin slightly so it would latch strait.
Much ta for the help lads!
