Hs4 Or Hif44 On A 1098Cc
5 replies to this topic
#1 alexangas
alexangas
  • 14 posts
Posted 10 February 2015 - 05:39 PM
Hello all!
Im rebuilding my clubman which has an HS4 carb.
Ive been offered an HIF44 which I hear is great! But will it be great on my 1098cc engine or should I stick to my HS4?
#2 carbon
carbon
  • 2,590 posts
Posted 10 February 2015 - 05:45 PM
If your 1098 engine is fairly standard then I would stick with HS4
#3 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 10 February 2015 - 07:10 PM
As above, unless you've got a significantly modified 1098, then I'd stick with an HS4. Even a stage 1 tuned 1275 should run's fine on HS4, so there should be ample fuelling there for a 1098. If you want a slightly more modern carb then consider a HIF38.
#4 alexangas
alexangas
  • 14 posts
Posted 11 February 2015 - 06:10 PM
Thanks all for the responses!
It will probably end up as a stage 1 with a cam, but as recommended i will stick to my HS4.
Cheers!
Any tips on suspension kits?
#5 Cooperman
  • 23,315 posts
Posted 11 February 2015 - 07:19 PM
What will the car be used for?
You don't need a suspension 'kit' as such, just a pair of adjustable tie-bars and new bushes to enable the castor to be set accurately. The important settings are the rear with zero to -0.5 degs neg camber and 1 mm to 2 mm toe-in. This can be done by measuring, filing and welding a large washer onto the rad arm bracket which costs virtually nothing.
For competition some negative camber on the front can help.
#6 alexangas
alexangas
  • 14 posts
Posted 14 February 2015 - 03:50 PM
Thanks for the advice :)
