Spi Fuel Pump Not Priming
Best Answer AlexMozza , 16 February 2015 - 02:50 PM
Solved!
The fuel cut off was messing up, tock it of the car, a quick clean and reset the button, all working now!
Go to the full post
10 replies to this topic
#1 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 14 February 2015 - 06:44 PM
The fuel pump on my SPi 1996, is not priming.
I have checked all the fuses in the fuse box, all good. I have checked the black box that sits above the servo. I have checked all the relays, and I am getting a resistance of 66ohms (+/- 1)
With the cover off, when the ignition is engaged the fuel pump relay operates for about 3 seconds, then the contacts open again.
I am at a loss at what to look at next!
The black and the white/purple going in to the fuel pump connector, the black should be going to earth, and the white/purple should be 12v live under ignition correct?
Any ideas would be great!
EDIT
It was working before removing the ECU and battery to conduct some welding.
I am unsure if it has an Immobiliser too.
Could this have done it?
Edited by AlexMozza, 14 February 2015 - 06:45 PM.
#2 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 14 February 2015 - 08:03 PM
 correct
try a direct feed from the battery to the pump; this will rule out the pump itself being the issue
#3 AlexMozza
AlexMozza
  • 1,248 posts
Posted 14 February 2015 - 08:05 PM
 correct
live to the pump from the battery, and then a earth circuit on the other pump connection?
I take it it will start regardless of the ignition position?
#4 AlexMozza
AlexMozza
  • 1,248 posts
Posted 14 February 2015 - 09:02 PM
By putting the pump direct to the battery the pump works, and the car runs sweet!
So I am guessing its either a bad wire or the realy box above the servo has failed?
#5 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 14 February 2015 - 09:08 PM
relay pack would be a suspect for sure, not the inertia switch is it?
#6 AlexMozza
AlexMozza
  • 1,248 posts
Posted 14 February 2015 - 09:28 PM
The relay pack I can see operating, plus the resistance in around 66Ohms, which according to Flying Scott's guide sounds about right.
The inertia switch Is the one by the wiper motor?
How would I test it?
#7 spiguy
spiguy
  • 1,537 posts
Posted 14 February 2015 - 10:05 PM
Try just pressing it first. Maybe you bumped it and tripped it. Just push the center of it.
#8 williams1980
williams1980
    Starting My Mini Up
  • 1 posts
Posted 15 February 2015 - 09:23 PM
I had the same problem with a non runner i purchased last week . I disconnected the inherit switch and ran a wire from the connection ( think it is the purple/ white if my short term memory serves me right ) . Anyhow its the feed going from the inherit switch straight to the pump . I connected this wire straight to the fuse box and up it came . Now i had to find the problem , no 12volts going to the inherit switch .The feeder wire from for power to the inherit switch is the brown / white and the fuse for this is located behind the carb . I cut out this inline fuse and soldered in a new blade type inline fuse and used heat shrink over the joints . That was it fixed . I replaced all the inline fuses in the same manner as I've a load of gremlins to sort out with the car .
#9 FlyingScot
FlyingScot
  • 2,664 posts
Posted 15 February 2015 - 10:54 PM
Different wiring on the later models...check first.
I take it you mean the fuel cut off switch Williams 1980?
FS
#10 AlexMozza
AlexMozza
  • 1,248 posts
Posted 16 February 2015 - 02:50 PM   Best Answer
Solved!
#11 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 16 February 2015 - 08:56 PM
 cough cough :lol:
