Mg Metro Or Kent 266 Cam
10 replies to this topic
#1 rusimir
rusimir
  • 129 posts
Posted 16 February 2015 - 08:11 AM
Hi
From experience, which cam is better MG Metro or Kent 266?
I want power from idle (lets say 1000RPM) up to 5000 (max 5500-6000RPM). I need all around engine, not hill climb or rally or drag engine.
And I need info for 998 and 1275 engine because I will tune both!
If You have any other good cam, be free to tell.
Thanks a lot
#2 Cooperman
  • 23,326 posts
Posted 16 February 2015 - 09:44 AM
They are almost identical and you will not notice the difference.
IMHO that pair of cams are the best ever produced for road going A-Series engines, be it in a Mini, an A-H Sprite, MG Midget, ADO16, etc.
Time the cam in accurately at 2 degrees advanced from manufacturer's recommended setting when fitting a new timing chain to allow for initial stretch.
#3 Spider
  • 15,136 posts
Posted 16 February 2015 - 10:09 AM
Sorry, I would disagree here. The factory cam will be considerably more accurate. Only what I've found from experience.
Actually, in general, all the factory grinds were remarkably high quality.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 16 February 2015 - 10:13 AM
Hmmm, I have used Kent cams in various cars over many years and their quality and accuracy is superb so I would agree with Cooperman. But have you looked at the Piper 270? Just a bit 'hotter' than the 266 but still very driveable.
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 16 February 2015 - 10:18 AM
I assume you can't get a new mg metro cam so they're going to be 20 years old and have a fair amount of wear?
#6 Spider
  • 15,136 posts
Posted 16 February 2015 - 10:31 AM
This is just one checking sheet from a 266
Cam%20Checking%20Chart%202101133b_zps3w0
It falls well short of the advertised spec.
I have another one somewhere of a 276 (dual pattern grind) from the same grinder, only the Inlet and Exhaust durations were mixed up!
<Edit: I think AC Dodd of this forum also has similar experinces? >
Edited by Moke Spider, 16 February 2015 - 10:36 AM.
#7 rusimir
rusimir
  • 129 posts
Posted 16 February 2015 - 02:28 PM
Carlos, there is Kent 450/500 (copy of MG Metro cam), that is reason whay I was write MG Metro.
Tam, I didnt look piper 270. But You are here if You have experience with that cam (share with us).
#8 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 16 February 2015 - 02:50 PM
Kent 500 is the same profile, I think.
#9 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 17 February 2015 - 01:40 AM
I can  recommend the cam I have, a Swiftune SW05-07.  My car will pull from 1500rpm in top and peak torque at 4000rpm.
#10 rusimir
rusimir
  • 129 posts
Posted 17 February 2015 - 06:58 AM
Also, I hear and read that SW is very good cam for all around!
#11 PH5121
PH5121
    Just On Tickover
  • 7 posts
Posted 06 February 2020 - 11:32 AM
I've just found on a shelf under a liberal coating of dust a brand new, still sealed in the box Kent 266SK kit that I got many many years ago and never fit in my first mini.
I'd be grateful if anyone could advise if it would be suitable for installation in, and is there any gain to be had, if installed in my current (standard) 1992 1.3 spi Cooper?
