Hi Temperature Paint
6 replies to this topic
#1 sprite72
sprite72
  • 113 posts
Posted 16 February 2015 - 12:03 PM
Hi all is there a high temperature paint that I can paint or spray on exhaust manifold that will not come off .
#2 Spider
  • 15,142 posts
Posted 16 February 2015 - 12:09 PM
This is a good one
http://www.vhtpaint....cts/flameproof/
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 February 2015 - 12:58 PM
If you don't mind black, buy paint for a barbecue grill.
Most aerosol automotive high-temp paints have very few solids and a limited amount of binder.  They look good at first and quickly flake off.  Barbecue paint, particularly brush-on paint, has a much higher solids and binder content and stays put.  Don't be put off by any seemingly "lower" maximum temperature rating listed on the can... the barbecue paint will survive manifold and header use.
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 16 February 2015 - 12:59 PM
Wilko BBQ paint is meant to be quite good and reasonably priced
#5 Dusky
Dusky
  • 5,322 posts
Posted 16 February 2015 - 02:28 PM
VHT engine paint works on one of mine.
As does the auto K brake caliper silver.
It's still on, even after overheating the manifold ( very bad timing, was around 20 of 'delay' instead of advance... red hot manifold, still the paint survived..
#6 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 16 February 2015 - 02:35 PM
For it not to come off? Difficult as it eventually fade and fall off unless you get it ceramic coated.
#7 Cerberus
Cerberus
  • 989 posts
Posted 16 February 2015 - 04:08 PM
We sprayed the steel part of a manifold with some halfords aluminium rattle can VHT paint.  The engines been run a couple of times now up to temp and the painted bit still looks exactly the same.
Car isn't finished and on the road yet so not sure how well it'll hold up when getting dirty etc, but it's looking promising so far.
