Windscreen Wipers Touching Open Bonnet
Posted 17 February 2015 - 12:22 PM
Posted 17 February 2015 - 01:00 PM
I have this on mine. If I open the bonnet, then it touches them as I raise it past the point that it sits at when on the bonnet stay, which I need to do to get the stay into the slot on the inner wing. I usually just put the end of the stay into a hole on the front panel to avoid this. I have the black hook type arms, I do wonder if the previous owner has bent them out a bit to try to get better contact of the blades on the screen.
Posted 17 February 2015 - 01:01 PM
Yup, exactly the same. The wipers work fine, the bonnet is perfectly aligned so im leaving alone
Posted 17 February 2015 - 07:46 PM
