Best Way Of Removing Oil From Carb
10 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 22 February 2015 - 02:34 PM
I have taken my carb appart and my neighbour has kindly agreed to get it either chromed or zinc plated depending on which one he has to go to first with work. He has told me ineed to remove as much oil as possible from my carb otherwise it messes everything up. What is the best way to remove all the oil from the surface of the outside and inside?
#2 jt19
jt19
  • 745 posts
Posted 22 February 2015 - 02:36 PM
De greaser?
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 22 February 2015 - 02:40 PM
Be careful what you're plating, certain areas have quite tight tolerances and some of it might not work properly or even fit if it's too thick, ask if he can do just te out side of things like the dashpot and body, the float bowl is not so crucial but don't block up any holes. Back to your question, petrol and brake cleaner, even in the dishwasher works very well
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 22 February 2015 - 02:41 PM
i forgot to mention it is just the dash pot being done everything else is being left as it is :)
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 22 February 2015 - 02:42 PM
Don't plate the inside of the dashpot, or the inside of the tube down the middle
#6 Rocket.
Rocket.
  • 1,441 posts
Posted 22 February 2015 - 02:43 PM
If its just the dash pot being done just clean it with some brake or carb cleaner
Edited by Rocket., 22 February 2015 - 02:44 PM.
#7 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 22 February 2015 - 02:50 PM
can i ask would would happen if it was?
does wd40 remove oil ive not got any carb cleaner left?
#8 Rocket.
Rocket.
  • 1,441 posts
Posted 22 February 2015 - 03:04 PM
Can't say I've ever tried worth a go won't do any harm
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 22 February 2015 - 04:26 PM
As above, there are some areas of concern if you decide to pursue plating.
What you are calling the dashpot is really the vacuum or suction chamber.  The vacuum chamber is the part you see that is often polished by proud owners.  The dashpot is the oil filled dampener in the middle... the part with the plastic knob you unscrew from the top.  The piston with attached needle moves up and down inside the vacuum chamber.
As stated by Gremlin, several parts are made to close tolerances.  There are tight tolerances between the piston skirt and inside of the vacuum chamber.  There are also tight tolerances between the metal dashpot tube and the inside/top of the vacuum chamber.   When you plate a part you are adding material and closing up clearances.  Chrome and zinc are typically added on top of a flash coating of copper for a buildup of at least 0.001" on the surface.  That closes off inside diameters by as much as 0.002" which may prevent your carb parts from going back together.
While it is nice of your friend to offer to plate these parts, doing so may render your carb useless unless they mask off all inside surfaces of the vacuum chamber.  That can be done.  Be careful.  As for cleaning, you can start with spray carb cleaner followed by spray brake cleaner, then washing with MILD caustic cleaners.  Do not use strong caustic as it will eat away the surface of the die casting.  The plater is going to have their own pre-plating wash and cleaning process for anything going into the vats so basic cleaning by you should be enough.  However, plating will show ALL the flaws in the part, therefore, read up on how to polish these parts before you give them to your friend for plating.
Finally, did you know that you can buy decorative chrome covers for the vacuum chamber if you want the shiny look without the effort?
Edited by dklawson, 22 February 2015 - 05:45 PM.
#10 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 24 February 2015 - 02:24 PM
Nope .. wd40 is a kind of oil (well lubricant!)
White spirit, brake or carb cleaner (best, evaporates), ...
#11 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 24 February 2015 - 02:30 PM
http://www.ebay.co.u...Y-/141437437836
