Steering Rack Lubrication
7 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 27 February 2015 - 10:44 PM
My shop manual specifies BP Energrease FGL Fluid Grease to service the steering rack.  When I removed the rack gaiters, the lubricant that poured out looked like 90W gear oil.  Are they equivalent?
#2 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 27 February 2015 - 10:50 PM
Just use engine oil, itsas good as any gear oil, i know that modern gearboxes and steering racks have 10w40 engine oil from the factory
#3 Spider
  • 15,136 posts
Posted 28 February 2015 - 05:22 AM
Haha, engine oil would be so much nicer to get in there!  But they actually were filled with SAE 90 Grade Greabox Oil, 200 ml
#4 Dusky
Dusky
  • 5,322 posts
Posted 28 February 2015 - 11:46 AM
You can still buy sae 90 oil(atleast in Belgium you can). Just get the right oil in there then :)
#5 Cooperman
  • 23,326 posts
Posted 28 February 2015 - 11:55 AM
I normally use EP80.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 28 February 2015 - 12:13 PM
Corey, as above, use gear oil.  Frankly, 80 or 90 weight isn't going to make much difference.  Later cars used grease but the oil (any oil) will work better.  Just make sure the gaiters are in good shape and attached securely.
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,376 posts
  • Local Club: Amoc
Posted 28 February 2015 - 12:40 PM
To be totally honest. Grease will cost about £20-30.. Then hassle of new gaiters and seals.. 10-15.....
http://www.minispare...px|Back to shop
All in better idea least you know the rack is good......
#8 newenglandmini
newenglandmini
  • 646 posts
Posted 28 February 2015 - 01:29 PM
Thanks to all.  I'm installing new gaiters, so oil is the best choice.  Servicing with 90W is not a problem, because the rack is on the workbench.
by the way, my shop manual specifies that the rack oil capacity is 100 ml, not 200 ml as stated above.
