Steering Rack Replacement
4 replies to this topic
#1 nelo36
nelo36
  • 155 posts
Posted 28 February 2015 - 12:01 AM
Hi folks doing a rack change tomorrow on daughters car
But never done it before has any one done this and are there Ny tips on doing it
I know I have to jack up the car and put axle stands under body then jack under gear box undo tower bolts and rear mounts and power to have enough space to get rack out and the back in but I read some where about using a drill bit in the rack but don't know why could any advise what is for and where I put it
Thanks lee
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 February 2015 - 12:09 AM
There is a centering port in the rack that locks it in the dead ahead which you need to use when setting up the tracking and fitting the steering wheel. You stick a 1/4" drill or dowel in there to lock it up. It's at the non-driving end equivalent to where the pinion is at the driver's end. There is a plug in the passenger floor pan to access it.
#3 nelo36
nelo36
  • 155 posts
Posted 28 February 2015 - 08:02 AM
Cheers Dan
I'll take a look in a bit
Thanks lee
#4 nelo36
nelo36
  • 155 posts
Posted 28 February 2015 - 04:24 PM
well guys
2 hrs later rack is in and all working better than what came out but STILL got a knock on passenger front over pot holes etc
ball joints solid no play and  after all that turned to be simple thing as shock fuming thought i had checked shocks they are pretty new monroe
cheers for all the help guys at least i know how hard it is replacing  a steering rack
thanks
lee
#5 coopdog
coopdog
  • 4,506 posts
Posted 28 February 2015 - 04:33 PM
Knuckle joints knocking?
