Float Chamber Over Fliw
Posted 28 February 2015 - 09:06 AM
Just a quick one have recently replaced needle valve and gasket and now the bowl in overflowing it has a white plastic float is there any way to adjust the height of the float ?
Thanks lee
Posted 28 February 2015 - 09:31 AM
Heres the link to the su site, this ones for the hif type carb.
http://sucarb.co.uk/...tter-reassembly
or other carbs here if yours isn't the above.
http://sucarb.co.uk/technical/
does the new needle move freely with no sticking? if it does rub the sides down a tad with wet and dry.
Edited by alex-95, 28 February 2015 - 09:33 AM.
Posted 28 February 2015 - 10:39 AM
hi alex
thanks its a hs4 would this make a difference ?
thanks
lee
Posted 28 February 2015 - 12:19 PM
If this is the "all plastic" float without the bendable metal tab, your only adjustment is to change the thickness and number of small fiber washers used between the bowl lid and brass valve body. In a recent thread it was pointed out to me that these fiber washers are not even listed as spare parts or available outside of the rebuild kits. Back in the 1970s I remember all the rebuild kits that included a float valve came with these parts but their use was never explained.
Lacking those fiber washers you may be able to find copper or aluminum crush washers (at your parts store) that can be used to set the float level. Regardless, make sure the underlying problem is not debris or trash stuck in that new valve seat. It is not unheard of for old rubber hoses to sluff off bits of rubber when being handled.
Posted 28 February 2015 - 12:36 PM
Posted 28 February 2015 - 04:27 PM
hi guys
cheers for the help made a washer out of a spare exhaust manifold all great now no leaks
thanks
lee
Posted 28 February 2015 - 04:49 PM
I assume you mean that you made the washer out of an exhaust manifold gasket. Regardless, I'm glad this fixed it for you!
Posted 28 February 2015 - 06:14 PM
Cheers lee
