Oil Leak
3 replies to this topic
#1 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 28 February 2015 - 04:42 PM
Hi all , Can anyone please help my mini has a bad oil leak comming from under the fan area were the pulleys are
for the fan etc . Is this common . what is it more likely to be
thanks chris
#2 carbon
carbon
  • 2,590 posts
Posted 28 February 2015 - 05:34 PM
Could be the oil seal in the timing cover? This is just behind the lower pulley which has fanbelt to alternator and water pump.
#3 hellom8
hellom8
  • 188 posts
Posted 28 February 2015 - 06:07 PM
Had oil from this area before and it was the timing cover oil seal. I couldn't get the bolt undone to replace it, so a specialist changed it for about £100.
#4 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 28 February 2015 - 07:08 PM
there are 3 possible culprits. The oil seal in the timing cover, the timing cover gasket, where it meets its base plate, and then behind the plate, where the plate meets the engine.
The first should be most obvious to see, just try to wash the engine throughoutly. Then look carefully where the oil does leak.
