Engine
7 replies to this topic
#1 samusher
samusher
  • 10 posts
Posted 28 February 2015 - 09:20 PM
When ticking over it idles really fast and bogs if you rev it. Any ideas?
#2 Spider
  • 15,684 posts
Posted 28 February 2015 - 09:24 PM
Sounds like a manifold / vacuum leak somewhere.
#3 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 28 February 2015 - 09:26 PM
injection or carb?
#4 Cooperman
  • 23,513 posts
Posted 28 February 2015 - 09:41 PM
Too rich?
Too lean?
Retarded ignition?
Lack of oil in carb dashpot?
Too thick oil in carb dashpot?
Air leak in induction system?
Incorrect carb needle?
Edited by Cooperman, 28 February 2015 - 10:22 PM.
#5 samusher
samusher
  • 10 posts
Posted 28 February 2015 - 10:01 PM
Carb
#6 samusher
samusher
  • 10 posts
Posted 28 February 2015 - 10:02 PM
Thanks for the options ill check all those tomorrow
#7 samusher
samusher
  • 10 posts
#8 Cooperman
  • 23,513 posts
Posted 28 February 2015 - 10:29 PM
If it were mine I would first of all check dashpot oil for quantity and thickness and check that the dashpot can be raised with one finger and that it moves smoothly up & drops in about one second after you let go of it. Remove the air cleaner before starting to do all this. Use 3-in-1 oil or equivalent in dashpot.
Then I would adjust the tickover to 800 rpm.
After that I would loosen the distributor and wind on just a little bit more advance.
Then see if this has improved the throttle response.
If it did, I would re-set the timing to the recommended static figure (that's assuming you don't have dwell-meter).
Check the points setting at 0.015" and ensure the points themselves are clean & flat (assuming you have a points-type dizzy).
Once that is done, re-set the tickover and check the mixture.
Whilst doing these settings it is a good idea to fit new plugs, re-set the valve clearances to 0.012" cold.
Let us know if that cures it.
Edited by Cooperman, 28 February 2015 - 10:31 PM.
