Clutch Problem
2 replies to this topic
#1 minimejim
minimejim
  • 53 posts
Posted 01 March 2015 - 08:53 AM
Hi, I have just fitted put a 1275 in my mini and when I try and set off the car judders quite violently but when changing gear it's not really noticeable. Also when I set off and give it more than normal revs it goes a little better. Do you think this could be a buckled flywheel or something in the clutch assembly? Thanks
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 01 March 2015 - 09:37 AM
Sounds  like oil on the clutch plate or a worn out plate...
Edited by Guess-Works.com, 01 March 2015 - 09:37 AM.
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 01 March 2015 - 10:25 AM
As above, sounds like clutch slip
