Will a copper s head 11 stud large valves 32mm/28mm be ok to put on a 998 engine ?
Cooper S 11 Stud Head
paulk 7364
, Mar 01 2015 01:44 PM
2 replies to this topic
Posted 01 March 2015 - 01:44 PM
Posted 01 March 2015 - 02:00 PM
no,
for a start cooper S heads were 35/29mm valves ( early ones had 31mm exhaust),
the ports will be too big so it wont run great, especially low down,
also the valves overhang the bores, so you'll need to mod the block unless your using a very mild cam.
the std 1275 33/29 valve head can work ok, but really it needs to be on a pretty hot engine to make use of the ports,
Posted 01 March 2015 - 02:40 PM
Thank you for the info cheers
