Rear Subframe Mounting Bolt Snapped
Best Answer Ivor Badger , 01 March 2015 - 09:17 PM
Drill it and tap it, 8mm or 5/16" unf or larger should suffice. Then use a screw and large washer to hold on the mounting rubbers. There is not much load on the nut that's missing anyway, it just retains the rubbers.
Thanks ! when you say a screw and large washer where do you mean ?
Tap the centre of the broken stub to take a screw, use what ever tap you have above 8 mm. Order one off Chronos if you don't have tap. assemble the mount with the original washer and the put a thick large diameter washer on the screw and tighten the screw into the mounting stub to hold the whole thing together.
Screws are fully threaded to the head, bolts have a plain section between the head and thread.
Go to the full post
6 replies to this topic
#1 Rocket.
Rocket.
  • 1,441 posts
Posted 01 March 2015 - 01:46 PM
As title my rear subframe mounting point (the one that attaches to the boot floor) bolt has snapped there's a few topics on here of people having the same Problem but no definitive answer as how to go about fixing it.
Don't wont to replace the subframe because its fine apart from this
Anyone have any ideas ?
BC912FA4-09F7-4EAD-8928-E3AE902A76D9_zps
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 01 March 2015 - 02:55 PM
You need to cut a hole in the sill, then heat and penetrating oil on the stud
#3 Rocket.
Rocket.
  • 1,441 posts
Posted 01 March 2015 - 03:00 PM
It's not on the sill it the mounting point on the rear subframe itself
Where the rear trunnion mounts on to the boot floor
#4 Ivor Badger
Ivor Badger
  • 846 posts
Posted 01 March 2015 - 03:22 PM
#5 Rocket.
Rocket.
  • 1,441 posts
Posted 01 March 2015 - 03:35 PM
#6 Ivor Badger
Ivor Badger
  • 846 posts
Posted 01 March 2015 - 09:17 PM   Best Answer
#7 Rocket.
Rocket.
  • 1,441 posts
Posted 01 March 2015 - 09:24 PM
Thank you very much ! just the answer I was looking for :highfive:
