My speedo stopped working so I disconnected the cable from both ends and the cable has failed/broken.
The clock end has the White push/click fitting and the gearbox end has the screw type fitting. On the gearbox end do I have to remove the drive from the gearbox to fit the new cable or can I simply just screw in the new cable as is? Not really clear how it locates to the drive. Does it simply push in as I tighten the screw? I found this picture online but still not certain. Any advice would be appreciated
Edited by henb12, 02 March 2015 - 01:41 PM.
