Engine Seized
5 replies to this topic
#1 Shawbags
Shawbags
  • 159 posts
Posted 03 March 2015 - 10:16 PM
Hi all , I bought an engine for rebuild to get an idea of how easy/hard it was going to be so I went out to the engine yesterday and tried to turn it over with a large spanner and no go , I know the engine had been standing outside for a few years so half expected it not to turn , can anyone advise what part of an a series engine would be more likely to seize up first or would it be a number of places , cheers shawbags.
#2 Spider
  • 15,021 posts
Posted 03 March 2015 - 10:25 PM
The ones I've been given like this usually have 1 or 2 rusted bores and I mean really rusted. Some I've managed to save, but there's also been a few that have been scrap too.
Lift the head and have a look or you maybe able to see just by pulling a spark plug.
#3 sledgehammer
sledgehammer
  • 3,102 posts
Posted 03 March 2015 - 10:26 PM
I would guess - piston ring to cylinder would seize first - esp if ports open or no spark plugs
whip the head off , & pour a little diesel around each piston , leave a few days
see if you can get movement by rocking back & forward on fly wheel , or crank pully
you can tap the pistons a bit with a wide wooden drift /block
as above sometimes you can save the bore if slightly marked with a hone
but often it will need a rebore etc
if you do manage to release the pistons & get them out for inspection - look at ring retaining groove & lands
check clearance & for distortion as the rings will sometimes mark the pistons in this area
best of luck
Edited by sledgehammer, 03 March 2015 - 10:37 PM.
#4 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 03 March 2015 - 10:27 PM
acetone and atf, diesel takes too long.
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 03 March 2015 - 10:28 PM
Hi..Remove spark plugs and pour diesel into bores and leave for a few weeks checking that the bores stay topped up.....diesel will soak through and loosen siezuer....then try and turn engine over
#6 Shawbags
Shawbags
  • 159 posts
Posted 03 March 2015 - 10:36 PM
Thanks lads I will go with the diesel , cheers.
