Right then, 1994 Mini Cooper SPI
on my way home, just pulled out a junction. went in to first, second and third gear with no problem. pressed the clutch in and pulled it out of third and then went to go to fourth and it woudnt go in. then went back to third and woudnt go in. pulled over and it wouldnt go in to any gear with the engine running. just suddenly stopped dissengaging the clutch. the pedal now goes straight to the floor however the push rod out of the slave cylinder does move slightly but no where near as much as it should. there is fluid in the master cylnder and the hose is a goodrich braided hose fittend not too long ago. My suspicions are the slave cylinder has failed but would like to know if any one has had a simiular problem.
cheers
