so rebuilding tiny and the clutch arm was badly worn on the end as you can see,
Got a brand new one from a chap on here but when trying to operate it , its really stiff to operate, ie i can barely move it then "clunk" it goes through the motion, put the old one back in and its fine.
Thought it was the pin at first so machined 0.5mm off it and its still the same so its not that
as you can see side by side the old one is worn on the hole where the pin goes through and on the end.
any help gratefully recived!
really dont want to go and buy another arm
