Xylene Thinners
2 replies to this topic
#1 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 07 March 2015 - 08:49 PM
Basically I need to no what sort of mask is needed when useing xylene to thin zinc phosphate primer.
I've read up on the use of xylene thinner and it don't sound good death being the worst.
I used abit on a rag without mask for removing silicone and I got a blinding headache which I've never experienced from standard thinners or 2 k thinners.
I'm thinking about chucking it getting rid safely as I don't want to kill myself useing the stuff just call it bad judgement.
#2 Stu.
Stu.
  • 912 posts
Posted 07 March 2015 - 11:32 PM
The product safety data sheet should confirm what mask rating should be used. Have you had a look ? Hope your headaches cleared up.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 March 2015 - 11:33 PM
Air fed only I would imagine, Xylene is extremely toxic. Using Xylene carb cleaner even outside has had me reeling in the past.
