Offset Rocker Bushes
8 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 08 March 2015 - 12:02 PM
mate has just ordered some offset rocker bushes for his mpi
I assume there ok for the sintered rocker gear
are they easy to fit looks like they give 25 - 30 thou more lift
all helps bit here bit there
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 08 March 2015 - 12:09 PM
Nope, they are for the older pressed steel rockers.
Ac
#3 racingbob
racingbob
  • 3,061 posts
Posted 08 March 2015 - 12:26 PM
Ac
ah! I thought that might be the case
#4 carbon
carbon
  • 2,590 posts
Posted 08 March 2015 - 03:17 PM
If you do manage to fit the offset bushes to a set of rockers, then you shoud also either modify the pillars or find a set of the correct offset pillars which are like hens teeth...
#5 racingbob
racingbob
  • 3,061 posts
Posted 08 March 2015 - 04:50 PM
why do you have to modify the pillars after fitting bushes
#6 Swift_General
Swift_General
  • 871 posts
Posted 08 March 2015 - 06:19 PM
As otherwise the rocker will not sit where it should over the valve and pushrod.
#7 racingbob
racingbob
  • 3,061 posts
Posted 08 March 2015 - 07:13 PM
how
 hows that done, modify pillar
#8 Swift_General
Swift_General
  • 871 posts
Posted 08 March 2015 - 09:43 PM
how
If you us offset bushes then the centre of the bush is offset towards the pushrod end of the rocker. Moving it this way increases the lift to the valve end. Moving the centre of the bush that way means the rocker moves the other (i.e. towards the valve). The contact patch on the top of the valve moves and the pushrods are now leaning towards the valve unless the shaft is moved towards the pushrods by the same amount the bushes are offset to bring the rockers back to their original locations, hence the need for modified pillars. You may get away without - I don't know as I've never tried it but it would be ideal in any case. Not sure if you could modify standard pillars yourself or where currently sells them I'm afraid.
Edited by Swift_General, 08 March 2015 - 09:44 PM.
#9 carbon
carbon
  • 2,590 posts
Posted 12 March 2015 - 07:32 PM
The old 'workaround' here was to open out the stud holes in the pillars with a larger drill size, so the pillars could all then be moved so the rocker tips are centralised over the valve ends.
