Can Someone With A Sump Guard Off Their Car Take A Measurement For Me?
12 replies to this topic
#1 nicklouse
  • 18,998 posts
Posted 08 March 2015 - 07:10 PM
As my engine is out I can't do it myself of I would..
The height between the mounting parts and the inner surface of the guard.
If that makes sense.
-\___/-
#2 nicklouse
  • 18,998 posts
Posted 09 March 2015 - 10:31 PM
Guess I am crawling under a mini in a car park somewhere if I see one.
#3 Tupers
Tupers
  • 4,173 posts
Posted 09 March 2015 - 10:54 PM
I haven't got a sump guard but I can measure the distance from the flat edge at the bottom of the frame to the bottom of the gearbox case if that's any good?
Are you going to use this style of sump guard. Clicky
#4 nicklouse
  • 18,998 posts
Posted 09 March 2015 - 11:04 PM
No sump guard. That would be great.
I am flattening of the bottom of the whole car this time. Last time I had a hole cut for the sump to come through but this time I am doing it correctly.
Well as correctly as a bodger with a welder can. ;)
#5 Tupers
Tupers
  • 4,173 posts
Posted 09 March 2015 - 11:14 PM
Cool I'll get my rules out at the workshop tomorrow.
Have you considered raising the engine up in the frame so that the sump is level with the bottom of the frame? I've been thinking about raising it on my estate project to get the drive shafts a little closer to lever and to gain a little more ground clearance.
It might put that IDA on yours even close to the roof height though.  :P
#6 nicklouse
  • 18,998 posts
Posted 09 March 2015 - 11:20 PM
And as I have remote housing gear change ....
But on a rod type box. Running a proper coil over set up. Take a few inches out of the subframe towers and make up new rear mounts.....
A lot of reading of competion rules is needed.
And then the re reading.
For example "front spoiler is not allowed to flex" ok seems simple. But how much flex is permissible? Nothing is black or White.
#7 Tupers
Tupers
  • 4,173 posts
Posted 09 March 2015 - 11:28 PM
You should talk to someone at Ferrari. They seem to be experts on just how much wing flex is enough not to catch a rollocking.
#8 Spider
  • 15,684 posts
Posted 10 March 2015 - 09:50 AM
If - If - I get a chance tomorrow, I'll measure one up. From memory, they are actually tappered.
#9 Tupers
Tupers
  • 4,173 posts
Posted 10 March 2015 - 01:25 PM
As spider says there is sligh downward slope from front to rear. The best I can measure is 35MM from the bottom of the sump to the joint in the subframe shown in the second picture.
#10 nicklouse
  • 18,998 posts
Posted 10 March 2015 - 01:59 PM
nice one thanks.
#11 nicklouse
  • 18,998 posts
Posted 10 March 2015 - 11:18 PM
Erm second picture?
#12 Tupers
Tupers
  • 4,173 posts
Posted 11 March 2015 - 09:44 AM
Sorry the second picture wouldn't upload from my phone.
Here's the joint that I measure from. The sump sits more or less level so hopefully you should be able to measure down from there and run a lever off it.
#13 nicklouse
  • 18,998 posts
Posted 11 March 2015 - 10:01 AM
thanks again.
