Paddy Hopkirk Quick Shift?
13 replies to this topic
#1 tomBERTfrancis
tomBERTfrancis
  • 52 posts
Posted 08 March 2015 - 09:38 PM
Hi all was just wondering if anybody has bought the mini sport paddy hopkirk quick shift gear stick and if so what are your thoughts on it?
#2 tomBERTfrancis
tomBERTfrancis
  • 52 posts
Posted 09 March 2015 - 07:58 AM
#3 racingbob
racingbob
  • 3,061 posts
Posted 09 March 2015 - 09:31 AM
don't know about the paddy hopkirk one but I went to see a car once
and had one of these quickshift things and was awful
also is it just the minisport one with his name on
hope someone can tell you
#4 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 09 March 2015 - 10:14 AM
Yeh if you do. Dont buy the one with his name on lol. Waste of "extra money" for some letters. Go kad if you do
#5 nicklouse
  • 18,600 posts
Posted 09 March 2015 - 10:57 AM
none of them are Quick shifts. they are Knob travel reducers.
the seep of the shift is limited by the syncros.
on issue with reducing the travel of the Knob is that the sideways gate is also reduced. so you have to relearn the positions and take care with the shifting so you do select the gear you want.
pointless bit of metal.
#6 racingbob
racingbob
  • 3,061 posts
Posted 09 March 2015 - 02:08 PM
yes awful things
#7 jonny-boy92
jonny-boy92
  • 70 posts
Posted 09 March 2015 - 03:20 PM
I have the new KAD "quickshift" and have to admit it is a great bit of kit. It has a quality feel to it and slips into each gear brilliantly, plus it has the little lift up lip underneath the knob to get it into reverse. If you're gonna get one get the KAD one...I wouldnt bother with any others
#8 tomBERTfrancis
tomBERTfrancis
  • 52 posts
Posted 09 March 2015 - 05:32 PM
thanks for the reply Think I will save up for a KAD one are they easy to assemble?
#9 nicklouse
  • 18,600 posts
Posted 09 March 2015 - 07:00 PM
The same as any other. But note if you don't like it a new casing is needed or drills, taps and a lathe to make bits and modify the one you have fitted the gearbox killer to.
#10 Cooperman
  • 23,294 posts
Posted 09 March 2015 - 09:55 PM
What do you want or expect to achieve by fitting one of these?
The answer will determine whether you will be disappointed or not after spending quite a lot of cash.
#11 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 10 March 2015 - 01:06 AM
Generally pointless, although I have used one in a Mini based kit to resolve clearance problems
#12 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,857 posts
  • Local Club: man Estate
Posted 10 March 2015 - 01:14 AM
In the middle of the rejuvenation of my mini, in a lull in the proceedings I was struck down with KAD fever and bought a quickshift.  I like it but you do have to be more gentle changing gear but then my old Dad trained me to never use more than two fingers to change, he used to arm himself with ruler when he was teaching me to drive and crack me over the hands if I was wrestling the 'box :-)
#13 lsto
lsto
  • 599 posts
Posted 10 March 2015 - 05:28 AM
I have a quick shift fitted to mine, I think short shift is a better name because it doesn't make the gear change any quicker, just reduces the travel of the gear lever. I prefer mine with it.
A lot of people dislike them as you can see from the many posts above filled with love lol.
As long as you don't think once fitted you can smash it into any gear as quick as a rally spec suburu impreza because all you do is destroy the syncro's. Just use it as a normal shift and you'll be fine, and yes they are easy to fit but stick to KAD.
Good luck :-)
#14 jaydee
jaydee
  • 8,565 posts
Posted 10 March 2015 - 10:57 AM
I wonder myself if paddy has ever tried one of those quick crunch..
