Door Hinge Pins Replacement
9 replies to this topic
#1 samg2007
samg2007
  • 499 posts
Posted 10 March 2015 - 12:33 PM
Hello,
I saw in a build log somewhere that someone had replaced the pin in the door hinge with a bolt. I cant for the life of me find which build it was.
Anyone have any thoughts on this?
#2 newenglandmini
newenglandmini
  • 646 posts
Posted 10 March 2015 - 12:46 PM
That would be a bad choice.  The pins are very inexpensive and easy to replace.  If a bolt were used, it would possibly have more play.  It would also wear very quickly because the bearing surface is reduced (i.e., the threads offer a much smaller surface than the correct solid door pins.)
#3 samg2007
samg2007
  • 499 posts
Posted 10 March 2015 - 12:53 PM
That is a very good point.
Maybe, it was some sort of rod, but maybe i'll just remove the pins.
Cheers mate
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 March 2015 - 12:56 PM
http://www.theminifo...rebuild/page-34
That it?
Edited by Ben_O, 10 March 2015 - 01:00 PM.
#5 samg2007
samg2007
  • 499 posts
Posted 10 March 2015 - 01:01 PM
cheers Ben_o , hadn't thought of searching.  ;D
Edited by samg2007, 10 March 2015 - 01:08 PM.
#6 tb205gti
tb205gti
  • 186 posts
Posted 15 March 2015 - 01:20 PM
Where do you buy them? It looks like Minispares only has new pins for the external hinges. Both my doors are hanging now :/
#7 newenglandmini
newenglandmini
  • 646 posts
Posted 17 March 2015 - 08:35 PM
I don't know.  I foolishly made the assumption that they were available and cheap.  It appears that they need to be replaced as per the above posts.
#8 samg2007
samg2007
  • 499 posts
Posted 18 March 2015 - 10:17 AM
http://www.ebay.co.uk/itm/171538795271
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 March 2015 - 10:38 AM
All well and good but the hinge itself wears too so replacing the pin won't take up all of the slop
#10 nicklouse
  • 18,735 posts
Posted 18 March 2015 - 11:00 AM
exacly. i took a hinge apart the other day as a bolt had sheered off and the pin was fine. but the pivoting bit that was where the wear was.
