998 Auto Rover City 1991 What Oil
17 replies to this topic
#1 Markmc85
Markmc85
  • 13 posts
Posted 11 March 2015 - 12:37 PM
Is valvoline 20/50 vr1 racing oil good for my auto or can any body tell me what's the best oil to use 👍
#2 jaydee
jaydee
  • 8,565 posts
Posted 11 March 2015 - 02:57 PM
A decent 10w40 will be a far better choice for an auto
#3 mr3speed
mr3speed
  • 408 posts
Posted 11 March 2015 - 03:50 PM
Should still be 20W50 no?
#4 jaydee
jaydee
  • 8,565 posts
Posted 11 March 2015 - 03:54 PM
You need it to 10w40 due to the torque converter, i wouldnt use any 20w50 oil on an auto.
I'm not an auto expert though, so ask guessworks for further advice.
#5 Markmc85
Markmc85
  • 13 posts
Posted 11 March 2015 - 06:06 PM
Thanks guys
#6 mr3speed
mr3speed
  • 408 posts
Posted 11 March 2015 - 06:14 PM
Be interested to know the outcome. Would of though 20W50 but.....?
#7 Markmc85
Markmc85
  • 13 posts
Posted 11 March 2015 - 06:30 PM
Will keep u posted then mate
#8 chuffed
chuffed
  • 131 posts
Posted 12 March 2015 - 09:07 AM
in my auto I used 10w40 mineral oil. Had no problems and started easily!
#9 mr3speed
mr3speed
  • 408 posts
Posted 17 March 2015 - 03:37 PM
What have you decided to use?
#10 forever17
forever17
  • 22 posts
Posted 17 March 2015 - 03:56 PM
tried several different oils in my 1275 auto over the years, the Valvoline racing is head and shoulders above any other, in my
opinion. go for it.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 March 2015 - 06:20 PM
You should use 10w40 or 15w40 ( actually what you use is more over governed by availability ) as it's primary purpose in an auto transmission is as a hydraulic fluid, and change it regularly.
So if it is not working as a hydraulic fluid then you will be going no where, no matter how good it is for the engine.
Edited by Guess-Works.com, 17 March 2015 - 06:22 PM.
#12 mikep12
mikep12
  • 73 posts
Posted 17 March 2015 - 10:16 PM
I may be getting a bit too old but I thought that 20/50 was the oil developed for the mini auto in the sixties. Mind if it works on 20/50 it will work on 10/40 or for that matter 10/30 as they will be better oils anyway and as they will be modern oils will be better at staying in grade.
#13 mr3speed
mr3speed
  • 408 posts
Posted 17 March 2015 - 11:03 PM
I though 20/50 too. The green stuff
#14 mab01uk
mab01uk
  • 12,488 posts
Posted 18 March 2015 - 08:17 AM
You could also ask for your options here.
Automatic Mini Register:-
http://autominiregister.proboards.com/
#15 jaydee
jaydee
  • 8,565 posts
Posted 18 March 2015 - 09:50 AM
Minis in the sixties come out the factory filled up with a straight 30 oil or similar.
We're now in 2015, industry has moved on and there are better fluids available for purpoise.
Edited by jaydee, 18 March 2015 - 09:50 AM.
