Knocking Sound
engine
20 replies to this topic
#1 Georgea2405
Georgea2405
  • 58 posts
Posted 11 March 2015 - 04:25 PM
I have a 1996 mini sprite. I have basically been hearing a knocking sound from the car. I initially thought that it was the CV joint as it happens when in low gear and sharp turning. However, I took it to a mechanic and he's said my CV joints are fine and they do not have any cracks and are not corroded in anyway. He has suggested that he has a look further as cannot see anything when underneath and I book it in for the day. Obviously this will cost me further, so I was wondering if anybody else has had a similar problem and if anyone has any advice on the matter?
Many thanks,
#2 nicklouse
  • 18,719 posts
Posted 11 March 2015 - 04:27 PM
i would take it to someone who knows something as this mechanic does not sound like he does.
#3 Georgea2405
Georgea2405
  • 58 posts
Posted 11 March 2015 - 04:37 PM
The mechanic specialises in classic mini's, and said I have used him for a very long time
#4 nelo36
nelo36
  • 155 posts
Posted 11 March 2015 - 04:48 PM
Hi mate
what side is it coming from i had the same problem thought it was the steering rack so changed that turned out to be shock
worth checking
regards
lee
#5 Georgea2405
Georgea2405
  • 58 posts
Posted 11 March 2015 - 05:30 PM
I'm not sure which side, but I would say it's around the passengers side footwell, when I took it to the mechanic it was a very loud knocking and he said something was loose around the wheel but he sorted that for me, now there is still a noise but it is much quieter. So because it was quieter, and the mechanic had done up whatever was loose, I am ruling it out that it is that
#6 Steve220
Steve220
  • 5,075 posts
  • Local Club: BMC
Posted 11 March 2015 - 05:34 PM
What did he say way loose? It could potentially be a hub ball joint.
#7 Richie83
Richie83
  • 1,495 posts
Posted 11 March 2015 - 05:35 PM
Are the engine mounts/steadies in good order?
#8 Georgea2405
Georgea2405
  • 58 posts
Posted 11 March 2015 - 05:37 PM
I think he said that it was the ball joint, but he tightened it up, the mounting points are in good order and I have shuck the engine block in order to see if it was anything hanging off or loose and I heard nothing from doing that
#9 MrBounce
MrBounce
  • 2,664 posts
Posted 11 March 2015 - 06:02 PM
Take a look at the rear mounts on the front subframe - and the floor they mount to. It's possible that the rubber has deteriorated to a point that the subframe can move, causing the knock. There also may be cracking to the floor.
#10 Georgea2405
Georgea2405
  • 58 posts
Posted 11 March 2015 - 06:17 PM
The floor is in really good condition and I think the mounting points are fine, I only had its MOT done two weeks ago and nothing was mentioned about them
#11 blackjack1986
blackjack1986
  • 107 posts
Posted 11 March 2015 - 06:20 PM
Just a quick suggestion, jack the car up an put your hands on top and bottom of wheel andgive it a rock backwards and forwards and see if there is excess play, I had a lot of knocking and scraping from the passenger side wheel last week, turned out to be the wheel bearing.
#12 Georgea2405
Georgea2405
  • 58 posts
Posted 11 March 2015 - 06:29 PM
I haven't got a jack, but the mechanic tigthened up the ball joint 10 days ago and surely it can't be loose already
#13 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 11 March 2015 - 06:38 PM
Unless it needs re-shimming.
#14 nicklouse
  • 18,719 posts
Posted 11 March 2015 - 06:54 PM
Well with the words you have said he said it does not sould like it.
But as it not as loud I would go back and ask about this other noise as it could be something different or the same that is still going to fail.
#15 Spider
  • 15,198 posts
Posted 11 March 2015 - 07:14 PM
I'm guessing here it's the steering rack.
