Removing Seized Piston
7 replies to this topic
#1 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 11 March 2015 - 06:29 PM
What is the best way to remove a seized pisotn.
Its number 3, on a 998.
I have tried tapping it out on the Con Rod, and on the base of the Piston.
\its been soaked in PlusGas too.
Any other ideas?
#2 Spider
  • 15,141 posts
Posted 11 March 2015 - 07:16 PM
I've had two over the years that were really stuck. I ended up inverting the block in the press and using brute force.
#3 AlexMozza
AlexMozza
  • 1,248 posts
Posted 11 March 2015 - 07:25 PM
Well, it will need a re-bore, so I might end up just 'going for it'!
Its being soaked in Diesel overnight
#4 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 11 March 2015 - 08:37 PM
diesel/atf and acetone
#5 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 March 2015 - 08:42 PM
I would heat shock it, if it comes to it
#6 wile e coyote
wile e coyote
  • 1,230 posts
Posted 11 March 2015 - 11:47 PM
Diesel will eventually work - can take weeks though! Chunk of 2" x 2" softwood and a mallet.....with increasing impact....
#7 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 11 March 2015 - 11:57 PM
My first attempt would be heat.  You'll have to have loads of it though 'because of all that cast iron.
#8 se_juggles
se_juggles
  • 1,043 posts
Posted 12 March 2015 - 09:20 AM
Jack hammer......
