No Power Going To Coil Any Ideas Or Help?
17 replies to this topic
#1 miniboy1993
miniboy1993
  • 274 posts
Posted 11 March 2015 - 07:25 PM
I have just brought a project that has been sat since 1997 currently it's turning over but no spark? I have checked the coil on a working car and it's fine. it just don't have any power going to it??
#2 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 March 2015 - 07:58 PM
Take a wire directly from another live, ie solenoid , to the +ve side of coil and see if it starts.
Do you have a meter or bulb to check there really is not a live when ign is on?
#3 miniboy1993
miniboy1993
  • 274 posts
Posted 11 March 2015 - 08:01 PM
I tested with the king lead on the coil with a spark plug attached to it and tapped it against the block and nothing :(
#4 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 March 2015 - 08:08 PM
That has nothing to do with the question you are asking!
Is there a live at the coil with ign on?
Lets establish that first, before we get to sparks at plugs!
#5 spiguy
spiguy
  • 1,537 posts
Posted 11 March 2015 - 08:54 PM
what year is the car?
#6 Spider
  • 15,163 posts
Posted 11 March 2015 - 09:22 PM
If you have a meter or a test lamp, check - with the key on! - that there is 12V getting to the Coil (White wire).
#7 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 March 2015 - 09:25 PM
Moke, see my first reply ;o)
#8 miniboy1993
miniboy1993
  • 274 posts
Posted 11 March 2015 - 09:34 PM
Tested White wire no power with ign on??
#9 Spider
  • 15,163 posts
Posted 11 March 2015 - 09:45 PM
OK, then I'd next check the Ignition Switch. They have a plug to connect to the loom, they often give trouble. Pull it apart (some have clips on the sides holding them together) and clean / check all the contacts. Might also be worth checking that you have 12V on the Brown Wire there in the loom side.
If no joy after that, then there's every chance that the Ignition switch is worn out.
#10 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 March 2015 - 09:46 PM
Jeez, you are not making this easy with your short replys!
If you cant be bothered to write properly, I cant be bothered to help
That's good advice from Moke by the way
Edited by ChopperHarris, 11 March 2015 - 09:46 PM.
#11 Spider
  • 15,163 posts
Posted 11 March 2015 - 10:56 PM
Sorry Chopper, for some reason mate, when I brushed through this, I thought you were the OP!
Yes, I agree,,,,,,,
#12 miniboy1993
miniboy1993
  • 274 posts
Posted 11 March 2015 - 10:59 PM
I am on my phone sorry for the short reply`s
#13 spiguy
spiguy
  • 1,537 posts
Posted 11 March 2015 - 11:04 PM
again, what year is it -  reason for asking, if it is an injection car then the diagnosis route is different, the injection ecu won't power the coil if the crank sensor signal is missing for example..
#14 Spider
  • 15,163 posts
Posted 12 March 2015 - 04:59 AM
Ah, OK!
#15 miniboy1993
miniboy1993
  • 274 posts
Posted 12 March 2015 - 08:14 PM
1982 mini Mayfair shorty
