Cheers all,
Recently obtained my first Classic Mini; a late model MPi. Been sorting common things to get it to perfect running order, but one issue that continues to elude me is the water temperature gauge. During normal operation, the needle never moves past C or the blue field on the gauge, yet the aux fan kicks in as needed so I know the engine is running warm.
What I've done to date:
-Replaced temperature sender connector (prior owner used Mickey Mouse connectors)
-Replaced temperature sender (aftermarket common replacement part)
-Replaced thermostat (88C/190F)
Yes, the thermostat is between the sandwich plate and thermostat housing and not in the head.
So after all this and running around town today, the gauge never really moved beyond C.
Now here is the fly in the ointment...
The prior owner had the MEMs and MPi removed, so now the car runs on an Electromotive Direct Ignition system with Weber DGV...
Runs well I must say, however, whenever surgery such as this takes place, there are always niggly bits that don't get sorted... like this temperature gauge.
So I ask you, because that sender spoke to the ECU as well as the gauge, by not having the ECU in the circuit, is there a reason why the gauge would read colder than normal?
Edited by BlueFunk83, 15 March 2015 - 03:07 AM.
