Mileometer Not Working
4 replies to this topic
#1 wingnut
wingnut
  • 465 posts
Posted 15 March 2015 - 06:43 PM
Took the pickup for a spin at last today,but noticed the mileometer wasn't working.Speedo works fine though.Any ideas what this might be
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 March 2015 - 08:18 PM
Internal failure of the instrument, both parts are driven by the same cable.
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 March 2015 - 09:24 PM
As Dan said, it's an internal failure.  The cable drives a worm and pinion gear which in turn actuate a pawl that advances the odometer wheels.  If the speedometer itself is working then you know the worm gear is turning.  The problem may be a failed pinion gear, worn pawl, or damaged pawl spring (when/where fitted).  If you are not comfortable opening the speedometer up to work on it, this is a repair for professionals.
#4 wingnut
wingnut
  • 465 posts
Posted 15 March 2015 - 09:34 PM
Ok,thanks for your speedy replies.How hard is is it to take the speedo out so I can have it repaired,and who do you recommend to repair it
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 March 2015 - 09:45 PM
I am probably a few thousand too many miles away to recommend a repair business.  I'm sure others will post suggestions for places like Speedy Cables.
The Mini was in production for several decades.  Mine is a '64 with the center binnacle so I can only offer suggestions on how to remove it, not the later gauges positioned in front of the driver.
