Hi guys,
what is the diffrence between KAD rear anti roll bar kit 3/4' bar or 5/8 bar'?
manny thanks, jure
Posted 17 March 2015 - 06:00 PM
Hi guys,
manny thanks, jure
Posted 17 March 2015 - 06:02 PM
Posted 17 March 2015 - 06:09 PM
Posted 17 March 2015 - 06:39 PM
1/8" diameter.
what does that mean. as you may know already english is not my first lenguiche so can you tell me please tell me what is the diffrence between those 3/4 and 5/8 bar?
Posted 17 March 2015 - 06:42 PM
Posted 17 March 2015 - 06:43 PM
Posted 17 March 2015 - 06:45 PM
1/8" diameter.
Posted 17 March 2015 - 06:49 PM
Posted 17 March 2015 - 06:52 PM
1/8" diameter.
Posted 17 March 2015 - 09:58 PM
For racing, the rear anti-roll-bar promotes oversteer. By stiffening up at one end, the road-holding is improved at the other end, thus a rear ARB transfers some of the road-holding to the front.
So on a race circuit, once the ARB has been used to promote turn-in oversteer early in the corner, the power can be applied without too much understeer developing so increasing the corner exit speed and thus the terminal speed down the next straight.
So the thicker ARB fitted, the more oversteer you will have. If you go with too thick an ARB the car will want to spin.
That is a bit of over-simplification, but the idea is right.
An ARB will allow braking later into the corner as the back will start to 'come round', then full power will balance it out and prevent the car from spinning.
Quite useless on a public road, of course, as you may not be able to corner on that sort of limit with the ability to use full power through a corner. It would not be conducive to keeping one's driving licence either .
I hope this helps.
Posted 18 March 2015 - 07:01 PM
One is 19.1 mm and one is 15.9 mm , if that helps in metric .
Edited by Bubblebobble, 18 March 2015 - 07:20 PM.
Posted 18 March 2015 - 08:36 PM
I had assumed that the OP wanted to know what effect on the differences in vehicle dynamics would be with the two different sizes.
Posted 18 March 2015 - 08:44 PM
I assumed as well as that he did not understand imperial !
Posted 18 March 2015 - 10:05 PM
I wonder which he wanted.
Posted 18 March 2015 - 10:44 PM
But how it effects the handling and weight distribution depends on the the car and what it has been built for. You are definatly a dirt driver. And I don't mean that as the surface but the style.I had assumed that the OP wanted to know what effect on the differences in vehicle dynamics would be with the two different sizes.
Edited by nicklouse, 18 March 2015 - 10:44 PM.
