Here's an odd one that's been puzzling me for a while. I completed a full engine/head/carb/gearbox rebuild a year ago and have put about 1500 miles on it (spec below). To be safe when running in I fitted a wideband O2 sensor/gauge (sensor fitted in the Y-collector) to monitor the mixture. Runs very sweet when playing on the country roads (i.e. flooring it in 2nd/3rd/4th gives a great kick in the kidneys!). Under those conditions I see the O2 lambda drop into the nicely rich low 0.8's or a tad lower). However if I'm cruising at motorway speeds then floor it in 4th it goes very lean (1.1 to 1.2 lambda). If the O2 gauge was't there I probably would't notice it as it still pulls strong.
Can anyone think why it's running lean only under those conditions? It does't worry me too much as I don't do much motorway driving (plus I can 'compensate' by pulling the choke out a little!).
The only thing I can think of is that the head I inherited with this Mini had seen a lot of porting work. The inlet ports seem 'overworked' to me and I'm wondering if their larger diameter could mean lower airspeed through the carb/head hence not enough vacuum developed to rise the carb piston... hence running lean (but why only under those motorway conditions???). If so then would sleeving the inlet ports be something worth considering?
... or is there a more obvious cause and a simpler solution to this issue?
Another small issue that might be associated is that I pretty much always need to use the choke to get the engine started (and keep it on for the first few minutes driving)... even in this wonderfully warm climate here in California :)
Cheers,
Colin.
Engine/carb spec:
1380cc
3.44 FD
AC Dodds ACD-RS+ cam
1.3 Roller tip rockers
Heavily worked head (Stage3+??? ... 35.6mm inlets, 31mm exhausts... no room in there for unleaded seats)
10:1 CR
HIF44 (relatively standard apart from red spring, BCA needle, and LDZ 2085 damper)
K&N 7"x4" pancake filter with MSS44 stub stack inside
Megajolt ignition (still running a base map provided by AC Dodds)
Facet fuel pump + FilterKing... 4psi fuel pressure
