How Do You Remove A Centre Speedo
2 replies to this topic
#1 wingnut
wingnut
  • 467 posts
Posted 19 March 2015 - 10:03 AM
As the title suggests,how do remove the centre speedo in a mini pickup
#2 slidehammer
slidehammer
  • 1,202 posts
  • Local Club: LSMOC
Posted 19 March 2015 - 01:32 PM
If it is the same as the centre binnacle in a salon, you remove the trim pieces either side of the speedo by gently bending them outwards (towards you) until they realse from under the dash liner and the top dash rail and this will expose the screws that hold the single instrument pod to the buk head.(probable be a bit of sound proofing to move out of the way) Undo these and then unplug the wires / speedo cable and remove as a unit then turn it over and you will see thumb screws holding the clamp brackets in place. Undo these and the speedo head will come out forwards. I hope this helps. Just make sure if the srews are tight / rusty you don't round them off
#3 wingnut
wingnut
  • 467 posts
Posted 19 March 2015 - 03:59 PM
