Offset Sphere Joint
22 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 19 March 2015 - 08:39 PM
How do I remove the offset sphere joint from the final drive gear assembly?  Haynes suggests that it is pried off using the aluminum housing as a lever point, but I want to be sure that I'm interpreting the instructions correctly before I do so.
Attached File  PICT0049.JPG   87.98K   16 downloads
#2 nicklouse
  • 18,998 posts
Posted 19 March 2015 - 08:43 PM
http://www.minispare...600/18G1240.jpg
Is the tool for it or you can prise it off as it is only a C ring holding it on.
#3 Spider
  • 15,684 posts
Posted 19 March 2015 - 08:46 PM
Put a dolly behind it (on the diff side of it) and give it a sharp belt with a hammer.
#4 newenglandmini
newenglandmini
  • 646 posts
Posted 19 March 2015 - 09:14 PM
Is this the correct pry location?  I put a substantial bend on the pry bar without success, and I'm concerned that I may fracture the housing.  I haven't tried to hammer it yet.
Attached File  PICT0051.JPG   73.41K   21 downloads
Edited by newenglandmini, 19 March 2015 - 09:15 PM.
#5 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 19 March 2015 - 09:17 PM
Clump with a copper faced mallet works for me
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 March 2015 - 09:21 PM
You should have prised against the bolt heads before removing the diff side plates sadly. You are right to worry about prising against the ally, you will distort the side plates which are now no longer available. As Moke Spider says you can drift them off fairly easily now you have it on the bench like that.
#7 Alex_B
Alex_B
  • 4,573 posts
Posted 19 March 2015 - 09:22 PM
Pretty sure you should be prying off one of the bolts that mounts the diff side cover to gearbox, the ally housing would likely deform without support.
Since its off you might have to get creative but it doesn't take too much effort to remove them.
#8 nicklouse
  • 18,998 posts
Posted 19 March 2015 - 09:26 PM
As your diff it out. Dangle it by the cup and hit the ring gear with a dead blow hammer of soft faced mallet. Watch out for your toes. Don't let it fall too far.
#9 newenglandmini
newenglandmini
  • 646 posts
Posted 19 March 2015 - 09:36 PM
Thanks to all for your generous assistance.  I have the gearbox on the workbench, and I can assemble finger-tight to pry against the bolt heads.  I'll have at it again tomorrow and I'll report progress to close-out this thread.
#10 rww
rww
  • 154 posts
Posted 20 March 2015 - 08:54 AM
    These can be EXTREMELY difficult to get off or they can come off with no problem at all. I had to abandon all mechanical sympathy on one of mine by positioning two tapered metal drifts each side of the diff output shaft and driving each of them down into the gap between the joint and diff. cover. The drifts are driven in a little at a time equally and the tapers ease the joint off the shaft. It marks the diff. cover but it was the only way that this particular joint was coming off the diff.
Best of luck.
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 March 2015 - 10:34 AM
That was acceptable until recently, diff side covers were cheap and plentiful and pretty much required regular replacement anyway. In the last year or two they have become NLA new, and used ones are almost always distorted. Output shafts and pot joints however are easier to source. If you have to force it off cut the shaft, cut the joint, pull the plug out the middle of the pot joint and drive or drill the shaft out, but look after the side covers whatever you do.
#12 rww
rww
  • 154 posts
Posted 20 March 2015 - 11:00 AM
  I have had to use the tapered drift method several times. As I said it, 'marked' the centre raised radius of the diff side covers but they were completely re-usable.
 I suspect that the difficulty in getting the joints off is a miss-match of pot joint and output shaft circlip groove machining.
#13 newenglandmini
newenglandmini
  • 646 posts
Posted 20 March 2015 - 01:01 PM
Success!  I modified my ball joint pickle fork to create a suitable wedge tool.  The force of a heavy ball pein hammer was insufficient and I had to resort to using my engineers hammer.  I supported the side covers with a bit of scrap wood to avoid damaging them.  The side covers survived the ordeal.
Attached File  PICT0052.JPG   75.56K   18 downloads
Attached File  PICT0054.JPG   84.95K   10 downloads
Attached File  PICT0055.JPG   65.43K   11 downloads
#14 newenglandmini
newenglandmini
  • 646 posts
Posted 20 March 2015 - 05:23 PM
The side covers are available from mnispares.
http://www.minispare...ch/classic/diff cover.aspx|Back to search
#15 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 March 2015 - 09:29 PM
I believe these are reproduction, but they are very good news.
