Headrest Removel
9 replies to this topic
#1 944turbo
944turbo
  • 75 posts
Posted 23 March 2015 - 07:06 PM
Could I ask if anyone knows how to remove the headrests on the later type 90's leather seats please,I was told they should just pull out but they don't it looks possible that they have some sort of lock to them.Any help with this please many thanks.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 23 March 2015 - 07:17 PM
There is a button that needs to be pushed in on the seat where the headrest goes through.
#3 944turbo
944turbo
  • 75 posts
Posted 23 March 2015 - 08:51 PM
Can you give me a little more info alex-95 please on my seats were the headrest pillars go into the seat there are round black plastic finishers is it on them or do you need to look under them.Hope that makes sense many thanks
#4 alex-95
alex-95
  • 6,042 posts
Posted 23 March 2015 - 09:05 PM
Have you got a picture of what seats you've got?
#5 944turbo
944turbo
  • 75 posts
Posted 23 March 2015 - 09:37 PM
 The seats alex-95 are the genuine rover black leather with cream piping and have the mini cooper imbossed into them,does this help many thanks
#6 944turbo
944turbo
  • 75 posts
Posted 23 March 2015 - 09:47 PM
Attached File  seats leather black.jpg   38.21K   5 downloads  These are them alex-95 many thanks
#7 alex-95
alex-95
  • 6,042 posts
Posted 23 March 2015 - 09:54 PM
There should be a button which you can kind of see in the below pic, push that in and it should come out
        down from this arrow            v1743511_656830794434926_3453852052699642
Edited by alex-95, 23 March 2015 - 09:54 PM.
#8 DFulton
DFulton
  • 158 posts
Posted 23 March 2015 - 09:59 PM
I think you might have to twist / press something on the other side to fully remove them.  I've done it hundreds of times when loading stuff into the back, as you can lift the front seats further.  I can't remember exactly what I do (and my mini's not here at the moment to check), but I think you press on the plastic base on one side to slide it up, and then press / twist slightly the other side to release it.  If doesn't need a lot of force.
#9 944turbo
944turbo
  • 75 posts
Posted 23 March 2015 - 10:05 PM
OK many thanks for your help with this will take a better look tomorrow and see if I can get them out.
#10 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 March 2015 - 08:19 AM
Here is how mine work..... close up pic of the small clip you push in
and then on the other side you can see how it works, ie the bits that are cut into the legs to adjust the height of it.
Push the clip all the way in and pull the headrest off. Only one side has the ratchet like stops on the leg.
